Use this procedure to configure or view LLDP global information.
- Select LLDP.
- Select the Globals tab.
- After you make the required configuration changes, select Apply to save changes.
Use the data in the following table to use the Globals tab.
Field |
Description |
lldpMessageTxInterval |
Specifies the interval at which LLDP messages are transmitted. The default is 30 seconds. |
lldpMessageTxHoldMultiplier |
Specifies the multiplier used to calculate the time-to-live (TTL) value of an LLDP message. The default value is 4 seconds. |
lldpReinitDelay |
Specifies the delay in seconds between the time a port is disabled and the time it is re-initialized. The default is 1 second. |
lldpTxDelay |
Specifies the delay in seconds between successive LLDP transmissions. The default is 1 second. The value is as follows: 1 < lldpTxDelay < (0.25 x lldpMessageTxInterval) |
lldpNotificationInterval |
Specifies the time interval between successive LLDP notifications. It controls the transmission of notifications. The default is 5 seconds. |
Stats |
RemTablesLastChangeTime |
Specifies the timestamp of LLDP missed notification events on a port, for example, due to transmission loss. |
RemTablesInserts |
Specifies the number of times the information advertised by a MAC Service Access Point (MSAP) is inserted into the respective tables. |
RemTablesDeletes |
Specifies the number of times the information advertised by an MSAP is deleted from the respective tables. |
RemTablesDrops |
Specifies the number of times the information advertised by an MSAP was not entered into the respective tables. |
RemTablesAgeouts |
Specifies the number of times the information advertised by an MSAP was deleted from the respective tables. |
